Error When I run SPCC on M15
After doing imagesolver and try to run SPCC on M15 gives an error says no stars found.
  • Hi James,
    I think I need a new rule on this forum.
    I think no questions can be asked without some screenshots! lol
    1. Is the image stretched?
    2. Did you run BXT?
    3. Did the console indicate there were sources detected? How many?
  • Search results:
    Total sources .............. 644
    Excess count ............... 0
    Reject count ............... 496773
    Total search time .......... 1.195 s
    Total I/O time ............. 8.667 ms
    Total I/O operations ....... 2486
    Total uncompression time ... 204.524 ms
    Total decoding time ........ 806.527 ms
    * Output binary file generated: C:/Users/james/AppData/Local/Temp/Gaia_SP_Y59HFWJGUEIM.bin
    Extracting catalog star spectrum data: done
    377 catalog sources found.
    Saturation threshold: 0.7370
    * Extracting PSF signal samples
    *** Error: No stars found (channel 0)
    Reading swap files...
    1441.241 MiB/s
    <* failed *>
  • HI James,
    What about the answers to 1 and 2?
    How about a screen shot of your image... the entire image and zoomed in?
    Yeah, trying to avoid downloading everyone's image to find the error (heavy lifting by the user is needed!).
    But... without more information, make the image available.
  • I figured it out from one of your videos.
  • Hi James,
    In case others read this message, can you say what the problem was and the solution you found in one of my videos (perhaps with a link to the video?)?
