Funny star shape
Adam
The Takahashi FSQ85-EDX is well known to create a so-called inverted lighthouse/hourglass effect on certain bright/large (as seen in the attachment).  Can you think of any approach in PI that could be utilized to make it appear more normal.  I do not want to remove it, just make it less noticeable.
1855 x 1800 - 125K
  • I do not have a great suggestion.
    One thing you can take advantage of is that stars are round (reference quote needed).
    If the issue is on one or two stars... you can grab a preview around a star.
    Then you rotate the image. Then substitute this back in place with lighten (maximum) using pixel math.
    That should work.
    I know.. you don't believe me.
    Make the file available. It is a 10 second fix. But only works on a few stars.. you couldn't do this on a field of stars.
  • What do you need? A single fits frame or the complete final image?  I tried to attach several files, both as a single fits and jpeg, as well as zipped files but nothing is attaching.
  • You would make the master light frame available via a cloud server (Google Drive, OneDrive, DropBox...etc).
    Remember to set the permissions to *anyone that has the link* can get the file.
  • This is what I get when I apply my trick.
    The lighten trick did not work... so I just did the clonestamp on the rotated image.
    Do you think this would make a good video to demonstrate?
    2299 x 1596 - 4M
  • Yes, please! Many users of the Tak Baby Q scope would very much appreciate this. This looks excellent!!
  • Adam
    I just watched the video and tried it on the Ha only image I sent you and then on the HOO version attached here.  Thank you- I am very pleased.
    6872 x 4385 - 3M
  • Great!
