WBPP and Local Normalization pop up screen for Highest PSF frames integration
So, what have I missed here.
Have I changed a setting or does an update now require for me to continuously press "Generate" or "Select" during Local Normalization in WBPP ?.
How can I stop this from happening?.
I can't find the cause. Thanks
4594 x 2486 - 12M
  • Yes, you changed a setting (nothing to do with updates... rarely is).
    Did you check "Interactive Local Normalization" in the Lights Panel of WBPP?
    It appears you did. You should uncheck it to the this automatically.
    You can show your WBPP configuration as a screen shot if you find I am wrong.
  • You are tight again!. How many times can one look at something and not see...!!!.
    Thank you
