I've been happily following along with the Fasttrack videos. I've diverged a bit by running 481 light frames through WBPP just to see how long it would take. I've gotten to the Image Solver video and I've run into a conflict I can't seem to solve.
I'm using the same light frame as the one used in the video; 000001_2022_02_19_02_32_09Z_c_cc_d    .
I checked that I have all of the same settings in the script interface. I do, except the "Optimize only" Option does not exist.
I start the script and it runs. There are some discrepancies in the information in the process console like "Searching for optimal magnitude limit. Target: 17366 Stars" is different from that in the video.
The process console gets to two lines of green text, that vary from the video;
* Using an automatically calculated limit magnitude of 16.98.
* Using the automatically selected GaiaDR3_XPSD catalog.
Then has the same seed parameters as the video.
It eventually fails at
Catalog Gaia DR3 (XSPD): 53627 objects. (A different value from the video)
The next line is all red text:  ***Error: Error: StarAlignment. sensitivity( ):   numeric value out of range:  -1.
I've done as careful an analysis of the information I have as I can. When evaluating a software problem I generally start with the big red letters. I just don't know how to influence the StarAlignment. sensitivity.
All advice most welcome, and thanks in advance.
