Hello Folks I would like to request some help for something I am doing wrong. The error I am experiencing is in the SPCC module, “no stars in Chanel zero”. I have deleted everything and rerun three times now from the beginning making sure I reset WBPP to defaults. I did run DBE prior to this. I have even tried running SPCC prior to DBE with the same results. If I run without a stretch it will run but I lose my nebula around the Pleadies & the results are red. So I am doing it wrong. In the fundamentals in the stretch section Adam said that the stretch could do this but I have found nothing to correct this. Can someone offer some advice. I can pass any data that I have.
Scope is 405mm, camera is ZWO 2600 OSC, Computer is ASIair plus, Data: Lights are 60 shots @ 60 sec, Darks, 20 @60 sec, Flats 20@ 5sec, Dark flats 20@ 5sec
FYI that error has also happened when I tried to process the Rossette Nebula. So this has to be something I am doing wrong. I have had successful runs but I am a beginner.
John
