When you install the GAIA catalogs... if you get a warning about "No Output Path Selected" ... do not worry! It is just because the box in the process is checked by default. You can uncheck it. What I show (by asking you to execute the process) is only a sanity check, a quick test that means things are correct. It expects you to output something.. but we are not doing that.
