* Using the APASS DR9 (VizieR) catalog (automatically selected).
** Warning: Not using a local XPSD database - online catalog access can lead to suboptimal calibration results.
Limit magnitude: 11.24
* Searching catalog sources
https://vizier.cds.unistra.fr/viz-bin/asu-tsv?-source=II/336/apass9&-c=52.371593 30.735921&-c.r=2.911821&-c.u=deg&-out.form=|&-out.max=50000&-out.add=_RAJ,_DEJ&-out=Bmag&-out=Vmag&-out=r'mag&Vmag=<11.24
19958 bytes transferred (unknown size)
236 catalog sources found.
Saturation threshold: 0.7107
* Extracting PSF signal samples
Fitting 10734 stars: done
Fitting 9985 stars: done
Fitting 9044 stars: done
* Computing color calibration functions
Robust linear regression (R-G): 0%
*** Error: Insufficient data: only 0 sample(s) are available; at least 5 are required.
Reading swap files...
NGC 1491 WORKFLOW
NGC 1491 WORKFLOW
