I'm starting out with a monochrome camera and I'm trying to understand the workflow to be undertaken to achieve a master file for of images from each filter. When I load the images and calibration files into WBPP The result is one large monochrome file rather that three separate files according to filter. I thought the solution would be to run a WBPP script separate for each filter set and then combine those but the stars are not aligned. It seems to me that calibrating, aligning and integrating monochrome images is pretty standard fair so I'm thinking I'm missing something obvious. Can you offer any pointers?
I have completed the Fast Training, although admittedly many months ago, and many others of your excellent instruction videos. I’ve been using an OSC until now.
You are right. I’ve been tracking the filter type in the filename and file structure but have now configured the capture software to track this data in the FITS header.
I actually didn’t have any difficulty associating the darks, flats, and dark flats with the correct light frames, it was just that the process only generated one master light frame combining all three filters. The solution you offer is the missing piece, at least for this data set. Going forward I will be more mindful of the filter setting in the capture software.
Thanks very much for your quick response.
Colin
