Hi Adam. Took about 6.5 hours of narrowband data on NGC 7635 (Bubble Nebula). I used WBPP to calibrate the data and then use Cosmetic Correction. I checked the data via Blink and then manually aligned the sub exposures via Star Alignment. I initially used Star Alignment at the base settings that are given initially when opening the process and without drizzle. The result was that only 8 of 95 subs aligned. I methodically changed the Star Alignment settings and ran it multiple times until I found limited success (36 sub exposures successfully aligned) with the settings shown in the attached file.
Not sure what the issue could be with the data other that some sub exposures showed signs of deformed stars. Would like to have you take a look at the data and provide your thoughts on what the issue could be and suggestions on how to address and correct the problem. My data can be found here -
I processed the data that did align and got what I think is an acceptable image (attached) but it would have been nice to have all the data to use. This was taken on my personal equipment from my backyard in Los Angeles. Thanks in advance...
Reggie
